I've now stripped a bathroom pretty much back to bare walls/floor. I now want to start putting it back together, starting with the floor...
The existing/remaining floor is T&G, about 22mm thick. It is in reasonable position [edit:condition!] i.e. no rot, and has only bashed about in a couple of places by plumbers and electricians. The joists centres are at 30/57/50/60cm spacing. I've got room for perhaps 15mm of additional material under the new tiles and adhesive.
So should I be adding ply, cement-based backer board, both, or something else? I've even had advice before that I should rip up the floorboards, sister the joists and add noggins, but I'd like to avoid that if not absolutely essential, not least because the bathroom (stud) walls are built on top of the floorboards.
The bathroom won't have a bath in it, just loo/sink/shower. It isn't going to be a wetroom.
