Am I correct thinking ip65 rated and gu10 led 4w bulbs fittings in a bathroom ceiling that is 2450 high is good and safe practice?
Is a fire rated housing the same as ip65?
I know the fire rating is to protect from external exposure of the electrics and heat rated (gu11)so as long as the housings are ip rated I should be ok to use in a higher than zone 2 fitting situation?
Zone 2 is up to 2.25m my ceiling height is 2.45m so 17th regs have no problem with mains voltage electrics in that position as long as 30ma rcd is on the circuit! am I right there?
