Bathroom Paint and Poor Ventilation
8 Mar 2015
West Midlands
Evening
I have a bad condensation issue in the bathroom - soon to be improved with a new window and extractor.
However I have an issue with the paint peeling off to the plaster on the ceiling and exposed walls that aren't tiled.
Obviously there is a slight difference in level. So when I repaint it will look odd.
Excuse the pic! But that's what happens...
full
Is the only way to get a neat finish taking off all paint back to the plaster?
I thought about feathering the edges with sandpaper but not sure that would be good enough
You certainly have a damp problem, but my guess is that the ceiling was never primed.
Possibly it did start to peel off as soon as I cleaned of the black damp areas.
That area of ceiling is directly above a very hot shower that is used up to four times a day.
I intend to use dulux bathroom paint when I do it and a base coat - just watered down emulsion.
In your position I would be suspect as to the stability of the remaining paint, and it would probably be a noticeable height difference with a silk paint - I'd strip it back if at all possible.
Regarding your repaint, I've not used Dulux's bathroom range, but I have used Zinnser permawhite - and it's excellent.
