Hi there....
I'm in the process of refitting my bathroom and have the situation where the cold feeds to the sink/bath and toilet are all from the mains feed.
The hot water is gravity feed (water tank in loft and hotwater cylinder in the bathroom)
Putting in a shower I presume I am going to have problems of balancing between the mains cold and gravity hot.. and have the problem of tap turned on elsewhere (kitchen, garden) that I'll get scolded!
Can I get away with putting an isolator in the cold feed to the shower and using the isolator part closed to regulate the flow.
I presume ideally that gravity fed cold is actually the better way to go?
If I wanted to run both hot and cold as gravity fed can I tee from the cold inlet from the hotwater tank... or is it better to run a second line directly from the cold water storage tank?
Thanks for your comments.
