- Joined
- 15 Mar 2019
- Messages
- 2
- Reaction score
- 0
- Country
The bathroom has 20 y/o cork tiles 'welded' to 18mm t & g Weyroc chipboard and the boards are 'nailed' to the joists with some gun-nails. Understandably, it creaks and croaks. I'm currently ripping it out. My local DIY cuts plywood to size but it doesn't sell t&g. Does it matter if it's t&g ? Joists are 15 1/2 centres. Your thoughts about using cementitious boards straight onto the joists ready for tiling ?
One final point.. could I use a less-than-18mm subfloor (which was fine with the thin cork tiles because the bathroom and the landing were not noticeably out of level) to accomodate thicker tiles or will it not be stable enough ?
Thank you for sharing your expertise.
