I'm changing a utility room into a bathroom and want to lay out the new electrics to then get them signed off (finally found an electrician willing to do so!). The room requires 5m of cabling to get from the main RCD to the room. I'd like to run an electric towel rail, lighting and extractor fan.
Can someone advise on:
If I can I run this off one circuit?
Whether I need fused, lit, isolator switches for both the rail and the extractor? I assume these need to be outside the room which is very awkward!
Size of electric cable?
Lighting will be led spots and two lamps next to mirror which are IP44 off a transformer.
Thanks!
Thanks!
