Hi All.
I am currently fitting a new bathroom, and am placing most items in new locations. I have worked out where I am going to run the waste pipes, but have a few questions about connecting them to the stack pipe.
My house has a flat roof extention on the side, which would make modifying the waste stack very difficult. I have discovered an unused connection most likely from the original toilet under the floor, but there is nothing for the sink bath or shower. I could possibly drill a new hole under floor level out to the stack, (which is actually in the roof of the extention) BUT.......the stack pipe is made of (I think) cast iron, which I understand is very difficult to work with, especially in the cramped location it currently is.
The toilet is in line with the 4" connection T under the floor, so connecting that should be easy. The question is can I connect the waste for the bath, sink and shower to this pipe without issue, or am I likely to get air trap problems when the toilet is flushed. I have read somewhere I could connect another 1 1/2" pipe to the stack higher up (which in this case is plastic so easier to cut) to create an air vent, but is this standard?
Sorry for all the rambling and I hope it makes sense.
Thanks in advance for your help.
