Hi there..
So after my previous thread about the underground drainage Im finally ready (after loads of help and advice from you guys) to start the job... before I start, Im of the mindset that I want to get everything sorted out in one go, so I just wanted to check that my bathroom drain pipes setup is ok or should the drain pipes be running elsewhere? The downpipe will be running into the back access of my new gully I will be fitting so I just wanted to check that everything was ok, or if improvements could be made, what they would be..
Thanks as always
Dougie.
Thanks as always
Dougie.
