Thanks for your answers. Yes, having put the bath in place it would be an uphill struggle. The wall on the right is internal to an extension room (doesn't go as far back as the stack pipe) so I can't send the bath waste that way. I think I could shoot a 40mm through the external wall (running below the WC waste) and round the corner back into a saddle on the stack. Would that be ok doing a u-bend back on itself into the stack?
Thanks again.
Whatever happened to the permissable diameters/lengths to prevent "induced syphonage "self syphonage" , when the need to fit anti syphon pipes , correct entry into stack etc etc , this trade is going to the dogs.
