Hi
I'm planning on adding under-cabinet lighting above the bathroom sink.
I've bought an LED lighting set on the advice of the salesman in a lighting shop and I'd like to know what my options are for installing it before I get the electrician in.
Firstly, the sink is semi-recessed into a plywood half-ledge that runs the length of the room and boxes in the pipework toilet cistern etc. Is the boxed-in area under the basin still zone 2 or is it treated the same as the area under a bath? I'd like to put the driver for the LED lights here as it will minimise disruption to tiling. The driver is IP68.
Secondly, is it acceptable to use an IP67 switch (something like this: https://www.rapidonline.com/product...ated+vandal+resistant+switches&moduleno=81479 ) instead of a pull-cord in zone 2? The LED set doesn't have a built in switch so ideally I'd have the push switch on the front of the boxing, the driver behind and the cables running through an existing channel behind the tiling.
Many thanks for your advice
Liz
Liz
