Hi all
I would like to place 2 batten holders in the loft which are then connected to a single plug that I can plug into a socket in the hall when required.
Would these batten holders be suitable http://www.toolstation.com/shop/Ele...Batten+Ceiling+Rose+Angled/d190/sd2633/p36209
What size cable do I require 1.5mm or 2.5mm also twin and earth or 3 core flex?
I also guess a 13amp fused plug is correct?
Regarding the wiring. I was going to wire the plug to the first batten holder and then take a spur off each connection in the batten holder to the other batten holder.
Also would the cable be ok to use to take a spur off an existing Fluorescent Tube to a second one in the garage.
Sorry for all the questions
Thanks MJ
Thanks MJ
