I need to batten out an existing plasterboard ceiling so that I can drop it just over 90mm and put new 9mm plasterboard on the battens (encapsulating the original plasterboard and coving for now).
I plan to use 45mmx95mm battens, 90 degrees to the joist, at 400mm centres, with the 45mm side against the ceiling, giving me a drop of 95mm.
I plan to drill out 55mm of the batten, and then use 100mm screws, so that I will end up approximately 50mm into the ceiling joist, as shown in the picture below.
Does that sound OK? Do I need to go the whole 50mm into the joists, or could I get away with less?
Any thoughts would be much appreciated.
