Our boiler was serviced on 31 January I was giving a print out confirming that the boiler was working at 97.5% efficiency.I mentioned to the engineer that for the last couple of months, the boiler never ignited first time and occasionally have to reset the lockout, but invariably it always ignites. The engineer could not find anything obvious so called Baxi, they suggested a new gas valve was required ( at this point the boiler was still working). The gas valve was fitted last Wednesday but the boiler refused to spark into life, various other components were changed including ignition board, the electrodes kit, and burner, a new door seal was also fitted all to no avail.Baxi then suggested another lead be changed this was fitted the following day, again no change.Over the last two years virtually every major component has been changed with the exception of the control PCB and including the heat exchanger.We have now been without hot water and central heating for 6 days, does anyone have any suggestions please. The maintenance company are now trying to say the boiler is beyond economic repair, even though it was working fine before they fitted the new gas valve and virtually all major components are less than two years old
