    Dismiss Notice
Baxi 100HE plus - Water Leak
Discussion in 'Plumbing and Central Heating' started by GasEmergencyServiceFCO, 8 Feb 2011.
  1. GasEmergencyServiceFCO
    8 Feb 2011
    2
    Thanks Received:
    Yorkshire
    Country:
    Hi all,
    Before I start I will give you some background info on myself - I work for the Gas Emergency Service in the East Midlands, I hold a full Gas Safe ticket with work (ESP, Meters, Pipework etc) and I also have a registration in my own name with Central Heating, Cookers, Fires and Water heaters. The main reason I did my own ACS was to do the odd installation or service for friends and family etc, but as most installers/engineers know, it never works like that. The faults soon start coming in.
    Today a good friend called to say he had a leak on his Baxi 100HE plus, (installed approx 7/8 years ago) so i popped round after work to have look. It appears that the leak is coming from inside the combustion chamber, running down the left hand side of the heat exchanger as you look at it. Is there a common problem with these? I cant see anywhere obvious where the water is coming from as the inlet and outlet to the HEX is on the right hand side. Water pressure is dropping so I am pretty sure it is system water that is leaking.
    After reading this site for a year or so now, i know there are some very knowledgable people on here - with much more experience in fault finding than myself. I would appreciate a bit of advice on this if possible.
    Many thanks in advance,
    Chris
  2. Sponsored Links
  3. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,094
    Thanks Received:
    1,093
    Norfolk
    Country:
    Chris, register yourself in the Combustion Chamber as this is gas related work as you have the covers off the boiler.
  4. GasEmergencyServiceFCO
    8 Feb 2011
    2
    Thanks Received:
    Yorkshire
    Country:
    Will do, thanks for the heads up!
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
