Baxi 105 HE Instant flow rate
21 Nov 2005
Sheffield
Can the temp be turned down on this boiler and flow rate increased, when the system is on hot the rate is ok but the temp is very hot
There will be a flow restricting device, which can usually be removed, as long as you realise your HW in the winter may not be hot enough for a bath if you don't turn the tap down. The temp will not then be controlled by the boiler circuits.
anyone else with any tips, where abouts this valve is and how to remove, and if it will cause any probs
Most combis have a restrictor/shut off valve on the cold inlet pipe. Might be a screwdriver slot on the Baxi. The restrictor would be in and around the pipework in that area, I don't actually recall where on a Baxi. But you can bet it is where there is a nut to undo, check obvious junctions around the pipework to and from that valve. Turn off stop tap and run a kitchen cold tap first.
Here
is NOT a picture of where it is :roll: . I expect it'll be where the cold water inlet pipe meets the input block item 80. Probably a small disc with a star shaped hole and O ring in it, which will fall out with the filter when you guess the right pipe union to undo.
The pic is at partsarena.com/baxi.
If you call baxi tec they might steer you to the part.
As you see it's a fixed 12 litre/minute one - check you are getting that, otherwise removing it will make no difference
