Baxi 105e .. cant get any water to it .
15 Oct 2016
I have the above & have notice that the pressure has dropped to near zero on the gauge on the front of the Baxi .. I have opened up the filler loop beneath the appliance & although you can periodically hear some water going through, obviously not a lot , also not a lot of pressure in the radiators either, but plenty of water in my taps washing machine etc .. Any ideas ?? cheers ..
Scrap that I thought it was a duo tec :ROFLMAO:, could be a stick check valve on the filling side maybe
Ta for reply, i will do later, the one valve is leaking slightly also, on the right side of the filling loop .. Switched the boiler of now as the pump was working but by the sound of it is was dry :(
