Baxi 105e CH problem
13 Oct 2008
Lancashire
I sadly own a Baxi 105e which packed in last night.
The led above the 60 degress is flashing which indicates a pressure fault.
The pressure is good, the pump is running but I have noticed the push switch isn't pushing out from the top of the divertor.
When I make the conection, the boiler fires up and it runs ok.
Should I replace the diaphragm in the divertor?
(I have also noticed the front one is leaking when the push rod comes out (HW) so should I replace this one too?
yEP and yep get the diaphragm kit that comes with the gland nut and change that too
