Baxi 105e (Fault on Fan or Flu)
16 Nov 2006
Hi Folks
Got the "fault on fan or flue" warning LED flashing on my boiler. Sometimes the boiler works but the fault is appearing more frequently.
The sound coming from the boiler is much more high pitched than it used to be so im thinking its likely the fan at fault (some discussions blame the PCB hence my thread)
(what do you recon swap out the fan?)
Thanks in advance
Rob
Cobblers.every 105e fan i have changed, it is because bearings have seized,,,nothing,whatsoever,to do with pcb
And you should never have been anywhere near the fan as it is out of your remit, you are not Gas safe registered so should not be touching what you are not legally qualified to work on
Rofl...you are a fool...Polish your crystal ball !
I do not need a crystal ball to tell me that you are not qualified to work on gas, the tripe that you post on here is enough proof, you haven't got a clue
What about the famous fan relay fault on the pcb where it runs the fan but no ignition?...always the pcb. Third worst pcb after the suprima and cxi
What about it,that does not make the fan noisy!
Durhamplumber, have grace to bow to those with knowledge :whistle:
If you are a registered installer, visit CC and do a search.
Posted a picture a while back why the OP is getting this fault code
