ch is fine.
Needle on differential valve does not move when hot water flows - no matter what flow rate. Checked diaphragm - looked ok but replaced anyway. Needle moves ok and doesnt seem to stick. Checked the two sensing pipes - clear.
When microswitch triggered manually then divertor operates, boiler fires up and heats water as normal so PCB seems ok.
have already replaced HE as hw took ages to heat up / start to run cooler when flow increased.
any ideas???
any ideas???
