I have a Baxi 105e about 5 years old, the pcb was replaced about 5 months ago following its complete failure, and everything has been fine until the last few weeks, the boiler now only works when it wants, theres no pattern, whether its warm or cold, been used minutes earlier or not. It does the same for the dhw and ch. Now for the strange part, whenever the front panel is removed (just the front panel) it works fine, I left the panel off for a few days and everything worked fine, so put cover back on and within hours it had failed again, now either this is a huge coincidence or removing the panel has some effect, have checked for loose connections bad earths etc and nothing. I am confused as to how removing the front panel could allow the boiler to work.
G
G
