Baxi 105e leaking from pushrod on dhw pressure diff valve
18 Sep 2007
Durham
Hi my boiler is leaking out of the push rod hole on the dhw pressure differential valve any ideas what to do to stop it ?
thanks michael
get a new front plate seal turn off electrical supply & the cold water main, open a hot tap to release water pressure remove the micro switch bracket, unscrew the old seal (hex nut) screw in new one, refit microswitch bracket turn on water & electrickery and test job done :wink:
hi again ive tightened the gland and the drip has stopped there was just a nut no seal behind it. should i get a new nut + will i need a new diaphragm (should the water even get to the gland)
mic
There is an o-ring inside the gland nut. You may have temporarily stopped the leak, but you would be better changing it. Follow the instructions above, its an easy job.
