Hi, recently my boiler has developed a fault where the low pressure/pump fault fault warning will come on most mornings. After a couple of minutes the error light will clear and it will start to come on, but sometimes it takes longer and is rather an issue requesting hot water. According to the boiler the pressure is 2 bar, and while operating between 2-3bar.
I've tried to add some pressure to the system to see if the fault will clear (not that I should need to) but I'm only able to get it to 2bar (nothing's coming out of the PRV) shouldn't I be able to add more pressure?
Thanks in advance.
Thanks in advance.
