Have you left the filling loop open ? you can bleed a rad to bring the pressure down but you need to find out why the pressure went up in the first place.
No the filling loop is closed, so i can just bleed a rad to take the pressure down. I have tried to clean the filter on the cold water feed but it seems very tight. Is that Normal? i.e. is it left hand thread?
