baxi 105e oressure problem
5 May 2009
Kent
can anyone help with the above problem
i have had a new plate heat exc fitted but still am dropping water pressure anyone got any ideas
hi
there are no water leaks just checked everywhere over the last year the boiler has had a new diverter valve,pcb board,plate heat exc,and a prv i think it only leaves me the ev will try anothe prv as thats the cheap option
Got any central heating pipes running under the floor ? a lot of pipes were run in the screed without any kind of protection, you might be one of the unlucky ones.
luckly for me they are all ok all wooden floors no water marks anywhere
checked everything i fiddled about with the prv and its still losing pressure but not as fast before i done that i did notice a small trickle of water coming out of the overflow fingers crossed its only thr prv
