hi
there are no water leaks just checked everywhere over the last year the boiler has had a new diverter valve,pcb board,plate heat exc,and a prv i think it only leaves me the ev will try anothe prv as thats the cheap option
Got any central heating pipes running under the floor ? a lot of pipes were run in the screed without any kind of protection, you might be one of the unlucky ones.
checked everything i fiddled about with the prv and its still losing pressure but not as fast before i done that i did notice a small trickle of water coming out of the overflow fingers crossed its only thr prv
