I've posted a couple of times regarding recent issues with my combi boiler and received great help..esp from muggles. Long story short...(my version it may not be totaly correct).. I had the PV replaced ( because it was leaking) by the guy who fitted the original system, 9 years ago. I then noticed that the pressure in the new PV was going up, so much so that I had to keep realising the pressure though one of the radiators. I posted on here (could not talk to the boiler guy..no problems at all with him but his wife was very ill so did not want to disturb him) After posting Muggles suggested that the plate heat exchanger DHW had probably got pin holes in it. I now assume this is what caused the original PV bladder to blow and the ensuing water rusted the PV and started to leak..
Right still with me?
Muggles gave me the part numbers I required for the new plate HEX and I duly fitted it...no problems at all.
Now my new problem is the pressure is now not holding to its 1-2.5 standard...I have to keep topping up...now I expected a little of this due to the oxygen coming out of the water and me releasing this via radiator bleeding...but its been a couple of weeks now and I'm still topping up every other day or so...
I thought I must have a leak somewhere but have checked all the rads, all around the boiler and pipe work as much as I can and nothing found. I am now stumped...
Any thoughts gratefully accepted as ever...
Al
Al
