Need some help guys.
My 105e has just started to play up, when i go to bed at night or go to work (dhw and ch off) the boiler fails to light when timed to do so, both the ch and dhw are effected. the boiler is showing a fault at the 60degrees led (poss pump problem says MI's). if i turn boiler off and back on everything works fine it seems that when the boiler is timed to turn off at 10:30pm the problem occurs.
i havent opened here up yet as im super busy at the moment, just hoping for some possible solutions before i do an internal inspection.
im a gas safer but dont do any servicing or fault finding. any help on the possible cause will be great.
cheers
cheers
