Baxi 105e ,that may have a problem or may not ?
depends. if you look at the pin, is it going all the way or not.first option would be to change the dia(cheapest). but seems a bit suspect that its gone down after year.might be worth checking the CW filter.failling that its the DV.
as per bg(shoot me :roll: ) any time we do anything to do with removing teh case ints, bp/gas rate combustion analysis.
as your working on a part of a gas boiler, even if its a water part its still in the boiler, you should do a burner pressure or gas rate don't think thats in the realms of diy do you
what a sad jobsworth nomark. :roll: its hardly rocket science ffs.
thats because at group services all you do is change parts till the boiler works, gas rates and burner pressures are not your strong point....
no need to replace the full valve, you can buy service kits for the full valve (water section and main body) for less than half the price of a full valve. personally i think whenever you work on a boiler you should either gas rate or take a burner pressure..saying that, you dont need to be a pro to take a gasrate and it does not involve disturbing any gas joints
not being argumentative
so if the appliance gas rates are deemed to be wrong how do you go about correcting them :?:
:lol: :lol: :lol: :lol: :lol: :lol: Pot calling the kettle black?! Did those two bg boys who killed the oxford powermax owner after 10 visits know about gas rates, combustion analysis and burner pressures? :twisted:
Face it ****ish gas are not in a position to criticise anyone.
