Baxi 105e
If changing yourself, before removing old PCB turn stats to 0 and selector to off, then using a screwdriver do the same with the replacement board and it will simply slip on, be carefull not to force anything, when you have fitted the replacement try turning all the knobs and make sure they turn freely, if they are stiff dont force them, it is possible to get the knob spindles 180 degrees out
