OK, over the past few weeks with the temps outside getting so low, my system has frozen up 4 times, it freezes up from the drain pipe outside the house then backs up in to the system causing the boiler to stop working, when you look inside the panel the 30deg light is flashing and no matter how many times I tried to reset it, it just wouldn't ignite, this is how I've finally cured it via my mate the plumber boy.
* to begin with remove the pipe from outside and defrost, then you can either shorten this pipe dramatically or temporarily remove whilst we have the bad frosts, lagging them only traps the cold air inside the pipe and potentially makes them worse (the water is freezing as it dribbles down the pipes and causing the blockage)
* If neccessary use an air dryer on the length of pipe which comes back through the wall to the boiler, because it's likely that the frost has backed right up inside.
* Now check the pressure guage, it needs to read about 1.3bar, if it's less, look under the boiler and you'll see 2 silver braided hoses with black valve taps on them, open both taps completely (quarter turn) untill the pressure on the guage reads 1.3bar, this only takes a second or so so be quick to turn both valves back to their original position.
* Now try to reset the boiler by twisting the switch anti-clockwise, if the amber coloured neon light for the flame doesn't turn on and the 30 deg red light flashes you'll need to go to the next step !
* If the water has backed right up into the boiler itself it will cause the electrics to shorten
- Turn the power off to the boiler ! "Important"
- using a screw driver slacken the 2 screws either side of the lower front panel and lift the white front off.
- you'll now see a small see through resevoir to your right with 2 elecrtical terminals on the top, these are the safety cut out wires which when wet trips the system out and prevents the flame staying on, all you need to do is gently remove both these cables, remembering which one is which, and dry them out using paper towel or toilet paper and also dry the small tray in which they sit.
- reconnect the wires, turn the power back on and try the reset switch, it should hopefully now be cured, if so replace the front cover, tighten the screws and make yourself a well earned cup of tea, if it doesn't work then I'm sorry but you'll need to call your local plumber boy.
- Please note I'm not a registered plumber just an home DIY person, I found this advise simple to follow from my mate and as a result found that I'd like to share it with others to save them some money and keep them warm !
Regards all and merry Christmas,
Nick.
Nick.
