Baxi 130 HE
DP
10 Dec 2003
Glasgow
Went to service this boiler couple of weeks ago.
Noticed the sealing (white stuff) from the burner edges was missing. Also the burner when it lights, causes the burner to emit a farting noise. Boiler did not do this when it was fitted about two years ago.
Does the boiler need a new burner?
Suggestions as to why the boiler is noisy (and cure) most welcome.
nope but it does need a new internal combustion seal, dont know if that will stop the noise but it will stop the boiler shutting down due to overheating the thermister by the fan
corgiman - i think he means the white edging from round the burner, not the door seals..
yes you do need a new burner, its causing the flame to become unstable and make the droaning noise. when you fit it, DO NOT TOUCH THE BURNER TOP, as it is very fragile...
and when putting back together, put locking washers on the conbustion box door bolts to stop them vibrating loose and destroying your door seals....
ohhh I see
Best not to touch it unless you are competent to do so mate
best get a CORGi person in
Since everyone who has posted so far is CORGI registered then we must assume that they are deemed competent!
Well I do apologise that I am not as up on everyones CORGI status as you are Agile
cor you can be a cold fish now and again cant you ;)
