This one is driving me up the wall.
I have an issue with a Baxi 133HE Plus.
End result is that it goes in to fault and locks out.
I think it is heating the DHW up to an over temp state but don't let me lead you.......
OK what I can see................
Heating works fine.
Turn on a Tap
Boiler switches from CH to DHW.
Lamp for DHW goes on.
Burner light goes on. (all good so far..!)
Turn tap off.
The DHW lamp stays on.
The burner sometime continues to run but not always.
House gets cold..! as DHW is the only thing being heated.
The above is intermittent.. I can turn the tap on and off a few times with no problem.... Then......
I have changed the flow switch.
I believe I have check the Temp sensors.
( I have spares and they read the same values.)
Help.!!!! Its driving me up the wall.....
Thanks in advance......
Heating works fine.
Turn on a Tap
Turn tap off.
