baxi 30 he condensing combi boiler
5 Jan 2009
Essex
HELP please
no hot water or heating, the fan / flue fault light comes on, flue not blocked have checked, over the last 4 weeks it does work maybe for 1 day of just 30 mins, intermitten fault but now not coming on at all. I got it working by turning it off and on a couple of times now it does do it,
get baxi out. these boilers are known for a problem with the combustion gasket seal. most are replaced within the first year .
Are you sure its baxi 30he combi model number does not ring any bells
P.c.b. fault.
cheers for support,
The air pressure switch, may sound like a stupid question but how is the air pressure increased is it only from filling with water ie 1.5 to 2.5 bar on front dial
cheers in addvance
Nothing to do with that , completly seperate its to do with fan which is inside the bit in theory you should not go into.
