my mother in-laws baxi bahama 100 (worst boiler inflicted on the general public)is giving me no end of grief. It started out only running for a few seconds, both CH & HW and then cutting out. I replaced the CH flow switch and that cured the problem. Now I have 2 problems:
1) the pressure swings high and low. I depressed the schrader valve on the expansion tank and air came out (no water)so it looks like that's ok. When checking the pressure on the expansion tank, what should it be and do you check the pressure at the schrader valve or do you rely on the system pressure???
2) the second problem is that it intermittently cuts out while running CH only(flame failure light comes on) I think this may be that the boiler is overheating. I'm never around when it happens, so I cannot comment on the state of the boiler at the time. Can anyone Help??
