baxi bahama 100 ignites then cuts out
19 Apr 2007
Durham
HI,having a problem with a baxi bahama 100 combi boiler,when switching the heating on or turning on the hot water tap the boiler fires for about ten seconds then cuts out,any ideas please as we have no hw or ch.
Could be split aps pipes or faulty aps its self. Could be fan venturi partially blocked.
When was it last serviced?
Thanks for the reply i don't think its been serviced for a while,i will see about getting it serviced asap.thanks
Got my problem sorted,turned out to be central heating flow switch,fixed at the cost of £23.Bargain.
gazthepottertonengineer said:
always flow switch on these cant believe baxpoti didnt put that as they are pants :?
Perhaps, I was looking too deep and missing the obvious?
mmm
can the ch flow switch on this prove then fail, I thought the beggars just failed
no wot happens is magnetite gets attracted to the magnet in the flow switch causing it to fail but it can quite easily get circulated around by the pump causing intermittent faults :D
cheers
Gaz top advice, I may have missed that one
so to cure this apart from fitting flowswitches every few months would a magna clean cure this
