baxi bahama leaking water
20 Apr 2014
Baxi Bahana leaking water on the left hand side of the heat exchanger. Removed heat exchanger and inspected. Replaced the o rings and replaced the heat exchanger, but it is still leaking water on the bottom left hand side. It stops if i turn on the hot water. Leak appears to be coming from the secondary circuit. I have spend 4 hours on boiler today. Need Help.
heating
did you renew the o rings or just refit the existing ?
If you refitted existing than you will have to remove them & fit new O ring kit Baxi part No. 241568
If it still leaks replace manifold plate 241163
