Baxi Bahama 100 Water Leak
11 Feb 2010
Cheshire
Hi Guys
I have a water leak coming from my Baxi Bahama 100 combi boiler.
Seems to be coming from the joint between the flow switch manifold on the right side as you look at it, and the heat exchanger , seems to be the lower seal ?? Is this difficult to solve ?
Cheers, any opinions greatly appreciated !
Some of those joints can be difficult even for a professional.
But with new seals they usually can be made to stop leaking unless the surfaces have been corroded and are uneven.
Tony
Hi Tony
Thanks for that
I did have a local guy come out and he replaced the flow switch manifold and fitted new seals
He was a bit of a Muppet, he struggled getting the main screw/bolt out which secures the manifold to the exchanger, he damaged the head, and then proceeded to put the old screw back in, he said he couldn’t tighten it enough to stop the leak, and he also couldn’t get it out because he had damaged the head !!
I basically told him not to come back, I removed the screw with a screw extractor and fitted a new one but it’s still leaking!
I have noticed some different o ring seals on eBay, they seem sturdier
http://www.ebay.co.uk/itm/331041066550?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Do you think it’s worth trying these; I am pretty good at technical matters, good with my hands so to speak
Cheers!!
There may be some other sellers a bit cheaper.
You really need to look carefully at the sealing surfaces and make sure there is no debris on them.
Silicone grease may help to seal and some on the screw thread will lubricate and create a stronger pressure.
Tony
Hi Tony
Thanks for the reply
So do you think those o rings would be ok, they are not the same as the originals, they were just a normal o ring?
I did tighten up the screw as much as i could and it was still weeping
I will take the manifold off and check the heat exchanger surfaces are clean and tidy
Do you think its worth replacing the heat exchanger while I am at it ?
Cheers
M :D
Another quick question please, how do I drain the boiler down to check/clean the primary flow switch ?
Cheers :D !!!
