I wonder if anyone can help!?
I have a problem with my Baxi Bahama 100 combi boiler. The problem was intermittent and now seems to be a permanent issue. When I turn on the hot water everything seems to work, the gas comes on (looks like a reasonable flame) and I start getting hot water. However after about 5-8 seconds the system stops and I am left with cold water. This happens with both the Central Heating and the Hot Water
I have read a number of previous posts pointing to the flow meter being a big issue on this unit (the comments on the Baxi Bahama don't seem great, and the flow switch is clearly not the best design).
Looking at the maintenance manual then with this issue the flow diagram points to the flame sense electrode, ignition cartridge of gas valve. Which relies on checking burner pressure (something for an expert). Although I have skimmed through the fault diagram and am going to check in order tonight.
My questions are therefore:
1) Does anyone have any experience and can make a suggestion?
2) Is there any way to check the flow meter is working with a multimeter? (open circuit = dead?)
Thanks in advance
Elliot
Thanks in advance
Elliot
