I'm having a problem (I think) with a BB 401 Back Boiler; the system is fully pumped with cylinder/tank & room stats and a 3-way valve. A faulty boiler pilot light thermocouple has just been replaced and all appeared well; however I'm recently finding that, when the room (or tank) stat is calling for heat the boiler will light up for a reasonable while, then shut off briefly (30 seconds or so) then light up again for a brief period (50 secs) and so on. At all times when this is happening the room (or tank) stat is always calling for heat - it's not switching off/on/off etc.
It seems that, even when the room (or tank) stat is calling for heat, the boiler stat beneath the gas fire is controlling the burner - you can hear it clicking off/on etc. in synchrony with the burner flame. Winding the boiler stat up to a higher setting initially causes the burner to immediately light up again and burn for a longer period before commencing the off/on/off cycle, but then the same process kicks in again - albeit at a higher boiler/heat exchanger temperature. The boiler stat is currently at position 4 (one step away from it's highest setting) as I type this, and the burner is cycling off/on/off at regular intervals.
The pump shaft is nice and free to turn and self-starts straight away when demanded; the pump speed setting switch (I never knew it had one) was on position 2 - it's now on position 3. The 3-way valve plays nicely and the hot water and all rads warm up quickly; room & tank stats control the system correctly. There's no unusual noises, signs of airlocks etc.
I've not noticed this behaviour before, so something's changed/not right....
Any ideas please - the pump has been suggested, however all upstairs/downstairs rads (4) are getting nice n' hot?
polybear
polybear
