My back boiler started playing up. Does not want to start. As a result no CH or HW. The funny thing is it gave some signs 2 weeks ago it started to be slow a t starting which means timer @5pm boiler actually kicking at 5.30. 30mins delay aprox
Although If CH eventually working HW will work but if I stop CH, HW not working on his own. When I got it serviced the guy said that a part was a bit sticky inside the boiler relating to I think the ignition not sure.
I called the home emergency cover and they asked me where was the pump and the valve? called previous owner and told me under floor boards, they wont touch the floor everything has to be visible.
He thinks the valve is stuck?
what do you think the problem is I need your expertise?
