Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
you would be surprised how common it is that when some people work on these boilers they dont put the thermostat Phial back in the boiler pocket and this is the symptom that gets reported
All seems to be working as it should now, borrowed the legionella temp set from work and it is swinging between 44-47c but the boiler stat setting is on low whereas the old stat was set at 1 1/4 perhaps this is down to the fact i did not put any heat sink compound in the stat pocket.
I ran it and observed the temp on hw and then ch and think i overlooked the fact that the ch will take longer to heat due to water quantity and that is why it fired all the time, doh. will put some heat sink compound in the pocket tomorrow and happy days all through a combination of a duff stat and user error which i put my hands up to.
Thank you all.
