Baxi Boiler 105e Diaphram change - O Ring?
22 Sep 2004
Hi All.
Hope i can get a quick answer to this as i have the Diverter off at the moment.
I have a small O' Ring with the repair kit (had a small leak), but i don't know where it should go.
There wasn't one when i took the front of the diverter off to repair.
Where does it go??
Many thanks
Andy
It's ok
I figured if it didn't have one when i took it off, then it doesn't need one putting it back together.
Maybe it fits behind the main assembly!
Andy
It can go in the back part but if its not leaking then you don't need to bother!
Tony
When you take the front gland nut off it goes on the pin then put nut back on . Its a belt and braces approach from manufacturers due to the amount that weep after a few years due to minute wear on the pin and gland nut.
