    Dismiss Notice
Baxi boiler red light after water switch off
Discussion in 'Plumbing and Central Heating' started by Neil Henry, 30 Mar 2019.
  1. Neil Henry
    Neil Henry
    8 Mar 2017
    36
    Thanks Received:
    Birmingham. United Kingdom
    Country:
    Morning guys,
    How would I rectify this. Installed a new bathroom sink yesterday, turned water off and drained it, but when switching the heating back on it sounded like someone was kicking the pipes (air most likely)
    The red light flashes on the boiler and won't go off.
    The boiler is a Baxi 18HE
  2. kidgreen61
    kidgreen61
    8 Mar 2009
    1,882
    Thanks Received:
    379
    Staffordshire
    Country:
    Assuming you drained the hot water pipe to fit your new basin, then I don't see how the two are connected, you don't have a combi boiler.
    Have you tried the reset button on the boiler?
  3. Neil Henry
    Neil Henry
    8 Mar 2017
    36
    Thanks Received:
    Country:
    Yes I have. Makes a load of banging and then goes back to red after about 2 mins.
  4. ianmcd
    ianmcd
    15 Aug 2010
    15,266
    Thanks Received:
    5,349
    Lanarkshire
    Country:
    The HW that comes out of your basin tap does not connect to the boiler in any way, you have done something else, when you say you turned the HW off what exactly did you do and where did you drain it from
  5. Neil Henry
    Neil Henry
    8 Mar 2017
    36
    Thanks Received:
    Country:
    I Turned the cold water off at the main valve. Turned the heating off and then switched hot and cold taps on to drain the system to replace the taps.
  6. Sponsored Links
  7. ianmcd
    ianmcd
    15 Aug 2010
    15,266
    Thanks Received:
    5,349
    Lanarkshire
    Country:
    if you did that the hw tap would take an age to drain as you would have had to empty the cold water storage tank, that is in your loft, you are not telling us everything, could be an airlock, but shutting off the cold main inlet would not stop the HW supply untill the cistern in your loft had emptied
  8. dilalio
    dilalio
    20 Mar 2009
    6,406
    Thanks Received:
    906
    Potters Bar
    Country:
    Plumber's Curse... You didn't touch it but it occured whilst you were working on a completely unrelated part of the facilties and is therefore your fault!
    • Like Like x 1
  9. FiremanT
    FiremanT
    16 Jan 2012
    8,068
    Thanks Received:
    1,528
    Uk
    Country:
    Probably a bit left field, but is this a completely new sink job or a replacement.?
    If a replacement, I trust you have connected to hot and cold, and not to the CH pipes?
  10. mcmoby69
    mcmoby69
    19 Jun 2011
    5,248
    Thanks Received:
    1,584
    Lancashire
    Country:
    primatic cylinder maybe?
    stuck pump, pure coincidence?
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
