Hi All,
I have a problem with this thing,been trying to fix it for a couple of days to no avail.
Had the house 2 years,always worked OK till now.CH worked OK last winter,I bled all Rads at first use last year and no probs,DHW always been OK.Pressure gauge has NEVER registered any pressure in 2 years.
On saturday I put th CH on for the first time since last winter,it got hot,,I bled the rads.All OK.
Then I couldn't get any DHW or get the CH to work again.
Tried opening the 2 valves on the pressure loop,yes they are turning properly,not just the taps sliding over the inners.
Fault light is coming on to indicate the CH sensor is faulty according to the online instruction manual.Had that out,it still has the white paste on it and looks OK.Tested it,no circuit through it with my AVO on resistance.Tried connecting the plug to it with another piece of wire,still no joy with circuit made.
When I switch it on after leaving it for 5 mins,the thing lights up normally on the LED's,I turn the tap on,the burner kicks in,the flame LED comes on,after about 5 seconds the 30deg led comes on,after about another 5 secs the 40deg LED comes on,then it trips out and the 80deg light flashes indicating the sensor fault.
So two questions,
How do I get the pressure gauge to read anything?
How do I fix the flashing LED problem?
Thanks in advance,
Dave
So two questions,
Thanks in advance,
Dave
