Baxi Combi instant 105HE problem
7 Jan 2009
Derby
Hi, I have a hot water problem which i cannot figure out. When there is a demand for hot water everything appears to work fine, but after a couple of minutes the water goes from very hot to just warm. If I switch tap off for a short time and back on again, there is hot water and the process starts all over again. Any advice will be sincerely appreciated.
Thanks in advance
Plate heat exchanger is probably blocked.Can be cleaned(not always successful)or replaced and more than likely will be system contamination thats causing the problem in the 1st place.
