While investigating poor DHW flow from my Baxi Bahama 100 I found that the tap on the cold water inlet was not fully open. When opening it fully the flow increases so much that the water only gets warm. ( I know mains water is a lot colder at this time of year)
Should the DHW Flow regulator cartridge be doing this and if so should I get it replaced? For the moment I've closed the tap a bit to give the right flow.
Thanks in advance.
Thanks in advance.
