Baxi Duo-Tec divertor motor
22 Mar 2006
I have a Baxi Duo-Tec 40 HE A boiler that is not heating the CH properly. It will come on and heat up to 72 degrees (as measured on the boiler LCD) then stops. It come back on when the boiler says the temp is 30 degrees.
As its not on all the time the rads are not getting warm.
A plumber has told me that the 3-way divertor motor needs replacing and also the valve cartridge as they are one piece.
I have had a look on 'tinterweb and it seems you can get the cartridge separately to the motor. Also the cost of these two parts is substantially less than his price.
Looking at the motor and the boiler instruction book it looks as though it could be possible for me to replace the motor??
It looks as though I need to:
1) remove the front case and the inner door panel
2) remove the plug on the motor
3) takeout the retaining pin between the motor and the top of the valve
4) lift off the motor and put the new one on
I assume there will be no need to drain the boiler for this.
Does this sound right?
Cheers
2 Feb 2010
Lancashire
Remove outer case, DONT REMOVE INER CASE,
Pull off plug to motor, pull out retaining clip and motor pops off,
Its a dry job so no draining required, check electric supply to boiler is off first!
22 Mar 2006
Thanks for the reply. That's what I thought.
Looks like my plumber might be being very creative with his pricing.
2 Feb 2010
Lancashire
How much ishe charging? And whats he doing? Replacing cartridge and motor only?
22 Mar 2006
I'm sure if whatever you cost to employ was made public, someone will put pressure to kick you out of a job.
Possibly, But I have already spent nearly £400 in the last few weeks and my boiler is now in a worse state then when I first asked for help. Said plumber is now asking several hundred more pounds for what seems like a 5-10 minute job to fit a part I can readily find on the internet for £30.
I have no problem paying people for there time and skill but I am not happy about being ripped off.
7 Oct 2006
Take the head off and turn hot tap on, pin should go in and out. If the spindle is leaking you will have to replace either the cartridge (no bypass) or the full valve (if it has the bypass). When you turn hot tap on does the flow (left hand pipe) pipe get hot ?
22 Mar 2006
He was quoting for motor and cartridge replacement and it was £230.
I thought he replaced the cartridge 3 weeks ago when I first spotted the boiler was leaking, I have a bill from him itemising a valve cartridge and labour. He know says he didn't replace it just repaired it.
I have lost faith in what he is telling me so I am trying to gauge whether I am being ripped off or not.
Anyhow I have taken a quick look at the boiler with the front plate off. I can feel the diverter motor moving but it is making a groaning noise.
From this I would suspect that the cartridge does indeed need replacing and that the motor could be ok?
27 Nov 2009
Herts & Essex
Then your issue is that the man is incompetent and therefore a rip off at any price. However even an expert will charge higher prices than you'll find on the web.
22 Mar 2006
Hot water is fine its just the CH.
When you say take the head off do you mean the motor?
Should I do this with the boiler switched on?
P
Phill Peck
My guess is he didn't read the instructions or didn't know its not as simple as wind it out and. Wind new one in if you do that the cartridge will snap :LOL:
7 Oct 2006
Turn power off, take head off, turn upside down and get someone to turn tap on and off, you should see the centre pin going in and out. Did you feel the flow pipe when the tap is running ? I know you say HW is ok but this is a quick check to see if diverters passing. And did you check if the valve has a bypass pipe at the back (i think the 40 does). Check with the power off.
22 Mar 2006
Cheers will give this a go tomorrow.
