As in first post the errors showing when it faults are E110 & E125 & now E133 has come on board!!
safety thermo and primary circulation cant find E133 at the mo.
Thanks again for the help, will split the pump shortly.
Well I removed the pump and checked it.....
it wasn't spinning so I just to say touched it and it was away turned the power off then on and it never ran so I started it again and left it running for 5 or so mins then off/on and it spun on its own, stuck it back in and wahooo!! hot water and CH fingers crossed it has sorted the problem, we can now get a shower thanks for all the help
