Baxi duotec 28he probs
28 Nov 2009
Cleveland
Having problems with my combi, keep getting error E110 and E125
sometimes its fine mostly its a pain, when the hot tap is run the boiler bangs and the pressure dial bounces it time with the banging then it errors, can anyone help?
Lol,
thanks for fast reply, it will work fine IE this morning 2 showers were had then when I went to run a bath it shut down with the errors?? now if the water is turned on it will bang etc.?
im guessing....
your boiler was fitted to the old radiator system, with no protection for the boiler such as a magnaclean.
you could try washing out the plate heat x
Yes it was,
potterton out baxi in,
it was only a couple of months old (but unused) when fitted (a week ago!) but the fitter quite rightly has said he only fitted it and never supplied it so its not really his problem :(
Yes it was,
classic
all the crap in your old system is now working its way to your new boiler :cry: :cry:
at the very least
get some decent cleanser in the system and let it run for a week or so
then drain :idea:
and you will still have to clean the plate h ex out
The problem is it wont run,
it ignites then speeds up to 99 degrees while making all sorts of noises then switches off!! :( no hot water... no CH :?: :?:
Check the auto air vents are open, one on top of boiler and one on top of pump.
Just checked pump and it is very hot for something thats not pumping hot water!! are these a sealed for life unit? can you remove and align spindle to check it spins in pump?
thanks for all the answers so far!! ;)
have a look at the FAQs at top of page, or look in boiler M.I`s
