Baxi HE - Error E119 but pressure is 1.2 bar
30 Aug 2011
Hi
I hope someone here can help. I have been looking through the forum but can’t find a solution to this problem.
My boiler stopped working this morning and was flashing E119 (low presure).
However, the pressure is around 1.2 bar. Is there something I am missing here?
Please help.
Fin
take it to 1.5. see waht happens, had them only kick in around 1.5 sometimes.
Some Baxi's have an issue with water pressure switches. Ideally needs replaced or cleaned if blocked but i have installed new ones only to have it do the same days later.
temp fixes are increasing the pressure higher or unbelievably turning the power off and on at the wall has worked a few times on promax boilers.
Thanks for the replies.
I have opened the two stop valves under the boiler but the pressure did not change.
